SCM machine with xilog controller help http://www-.luthiersforum.com/forum/viewtopic.php?f=10106&t=21490 |
Author: | Puresoundguitar [ Mon Mar 16, 2009 11:08 am ] |
Post subject: | SCM machine with xilog controller help |
Hi everyone, I'm currently in the process of building an electric guitar from scratch, and i'll be using the above mentionned setup. Would somebody be kind enough to load my programs and check for possible sources of error? Ideally somebody of the same kind of setup that i'll be using. Here are a few samples of the whole process so far. I'll glady supply the final programs if someone desires to use them for personal use. Thanks in advance |
Author: | Bob Garrish [ Mon Mar 16, 2009 3:45 pm ] |
Post subject: | Re: SCM machine with xilog controller help |
What CAM software are you using? I can see you've got CATIA there (must have a neat day job!) but are you using it for the toolpaths or just the CAD? Most CAM software has simulation which will let you check your paths, but if yours doesn't then you'd need to find someone with third-party simulation software like Vericut or Metacut (which is rare) to check the paths. |
Author: | Puresoundguitar [ Mon Mar 16, 2009 7:08 pm ] |
I'm actually using Catia as my CAD and CAM software. I can do my simulations to a certain level, but i was looking to test my programs in the closest possible to reality environment. I have Vericut at work, but it would be a real pain to configure it properly with all the correct machine specs. As you know, every machine controller as it's own `soul`, i mean certain aspects that are unique to every controller. I know Xilog and SCM machines are no exception, that's why i'd like to have a real life test. If you think you can give me a hand in any way, just let me know. Thanks in advance |
Author: | npalen [ Tue Mar 17, 2009 1:00 pm ] |
I can't help you on the verification but do have a suggestion. Make mockup blanks from cheap wood to check the programs. I would bet that you'll see something that you want to change. Nelson palen |
Author: | PaddyD [ Thu Jun 25, 2009 9:49 am ] |
Hi, I have an SCM Record 220 with Routolink (Xilog 3) control, i'm happy to help out with whatever you want Regards Paddy |
Author: | Shane Neifer [ Thu Jun 25, 2009 11:07 am ] |
PaddyD wrote: Hi, I have an SCM Record 220 with Routolink (Xilog 3) control, i'm happy to help out with whatever you want Regards Paddy That's quite a machine Paddy!! What are you doing on it? Good to see you posting here again as well! Shane |
Author: | PaddyD [ Thu Jul 02, 2009 11:24 am ] |
Shane Neifer wrote: PaddyD wrote: Hi, I have an SCM Record 220 with Routolink (Xilog 3) control, i'm happy to help out with whatever you want Regards Paddy That's quite a machine Paddy!! What are you doing on it? Good to see you posting here again as well! Shane Hey Shane!!! you can't keep a good Paddy Down!! I am using the machine for everything (well not coffee etc.....) its great, made in 1999, weighs in at just over 19000lbs!! two aggregate heads, and a 10hp spindle......... its a big brute, but perfect for body and neck making.... also chews through radius dishes quite nicely!! i'm feeding it with code from mastercam, which is in turn fed by models from solidworks, all good stuff! yeah it has been a long time since i posted on the OLF, but i'm back, i guess i just got a bit dissillusioned with the same old arguments going on all time, but what can i say...... i missed you guys! P.s Shane hows the Lutz Coming? any luck with harp guitar sets? Paddy |
